1984 Buick Century Service engine soon light
ROLANDO404
  • 1984 BUICK CENTURY
  • 6 CYL
  • FWD
  • 64,000 MILES
My father-in-law gave my wife a Buick Century Station Wagon very nice little car. The service engine soon light goes on only when she is park waiting for my daughters and then goes off when she gives it some gas. Also the idle seems to be low.
Thursday, September 17th, 2009 AT 9:46 AM
JDL
  • 16,098 POSTS
Welcome to the forum. Check trouble codes. Maybe an 02 sensor code? If this vehicle has a carb, I'd put a carb kit in it. The adjustment specs, come with the carb kit.
How long since a regular tune-up?
Thursday, September 17th, 2009 AT 10:05 AM
ROLANDO404
It only does this once a day. I did a tune up about a week ago spark plugs and wires. I also put new radiator, smog pump and alternator and changed the oil. It runs great. This started happening after I did this and changed out some old vacuum lines out.
Thursday, September 17th, 2009 AT 10:22 AM
JDL
  • 16,098 POSTS
Sounds like you've done some good up-keep on it. I'd check codes.
https://www.2carpros.com/forum/automotive_pictures/170934_aldl_22.jpg
If the datalink connector looks like the picture, you place a jumper wire between the A & B terminals, turn the key till the dash lites come on, no further. The check engine lite starts flashing, you count the flashes to get the codes.
Thursday, September 17th, 2009 AT 10:46 AM
ROLANDO404
Thanks I'll do that. I just took for a ride with my wife and It did not do nothing with me it ran great I did turn around a little vacuum that was the wrong way before I took for a ride maybe it was that. It said towards motor and the other was towards something thats on the carburetor cover.
Thursday, September 17th, 2009 AT 11:44 AM
Related Check Engine Light Content
Is it Safe to Drive Check Engine Light?
VIDEO
