Broken fob key, anti theft device bypass
130,000 MILES • 4 CYL • 2WD • MANUAL
BECKY BARNETT BIRD
Need to bypass anti theft device without using key fob.
Aug 1, 2020 at 11:20 PM
Unfortunately there is no way to bypass the system as it was designed against that. However, when you say you don't have the key fob do you mean the remote that opens the door locks?
If so do you still have a key that starts the engine? Try unlocking the driver door with the key and see if the theft light turns off.
https://www.2carpros.com/articles/how-to-reset-a-security-system
If this doesn't work then we need to pull codes and find out what it is telling us? Lastly did they just happen one day or did something happen to the vehicle to cause this?
Aug 2, 2020 at 10:24 AM
