Brake light on dashboard
15 MILES • 4WD
FONARMSTRONG
Brake pedal strong and soft then the brake light on dashboard.
Feb 22, 2020 at 3:43 AM
  • 110,248 POSTS
If the brake light is on, confirm that the brake fluid is full. Now, when you say the brake pedal is both strong and soft, I need some clarification. If it is extremely stiff, that sounds like a problem with the power brake assist system. If it is really soft and goes to the floor, that sounds like a leak or a bad master cylinder.
___________________________
Here is a link you may find helpful. It discusses a soft brake pedal or one that goes to the floor. If you get a minute, read through it and see if it seems to mirror what you are experiencing.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Here is another you may find helpful:
https://www.2carpros.com/articles/brake-system-warning-light-on
Feb 22, 2020 at 8:15 AM
