Change the rear brake shoe and drums? I need for rear brake drum removal?
CRAIG WITTWER
  • 2007 PONTIAC VIBE
  • 6 CYL
  • FWD
  • 100,000 MILES
What bolt thread and size do I need for rear brake drum removal? To use in the two threaded holes 180° from each other on rear drum used for drum removal. The holes are not to hold the drum at all or there would be bolts in the holes! When the tire comes off of this car for the first time, and the drums are about to come off for the first time, and there is no bolts in the holes, what size bolts and thread do I need for the holes?
Monday, February 13th, 2017 AT 9:46 PM
HMAC300
  • 48,601 POSTS
I gave you an answer to remove the drum that is the most common way mechanics do this sort of stuff. if you want to find the bolts then they will be 8 mm 1.25 or 1.5 thread. 12 mm bolt head
Here is a video to help you remove the drums without a the bolts
https://youtu.be/UV0kfP17Co0
Cheers, Ken
Tuesday, February 14th, 2017 AT 12:03 PM
CRAIG WITTWER
Ok this helps, thank you. I'm from Minnesota, so it's quite uncommon for these types of things to work anywhere near this easy. Thanks again!
Tuesday, February 14th, 2017 AT 12:11 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,247 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
Friday, December 8th, 2017 AT 8:13 PM
ROSE VERHEYN
  • 2007 PONTIAC VIBE
  • 84,000 MILES
My husband put new front brake pads on my car. Now the rears are grinding can you help?
Wednesday, June 9th, 2021 AT 12:30 PM (Merged)
https://www.2carpros.com/articles/how-to-replace-rear-brake-shoes-and-drums
Below is the process from the manual that will help with this as well.
Please let us know if you have other questions. Thanks
HOME4PEREZ
  • 2005 PONTIAC VIBE
My husband has a 2005 Pontiac Vibe. He took the Brake Drum off and at some point had our nephew step on the brake. Well after doing that he figured out that the brake drum will no longer go on and we can not find anything that states what to do. We have tried moving the Adjuster, but to no avail. Please help!
CARADIODOC
  • 33,863 POSTS
Check that the shoes are seated against the large anchor pin on top. You'll probably have to pull them away from the backing plate so they can spring back.
Be aware that serious damage can be caused by pressing the brake pedal all the way to the floor. Since the vehicle is only a few years old, that might not affect it but it is good practice to never push the pedal more than half way down.
MARS1022
  • 2005 PONTIAC VIBE
  • 1.8L
  • 4 CYL
  • 218,000 MILES
Was rotating my tires last night so I put my spare on the back left side and moved it to the front and when going to put the other tire on the rear the spare came off fine but I noticed when tightening the lug-nuts by hand the wheel would spin freely. I didn't think much of it until I went to lightly tighten them with my 4 way while it was still jacked up and then I realized the tire spinning like that had never happened before. The point it was spinning from was the front facing side or the drum. A weird noise is now coming from that brake and I'm worried I'm going to lose fluid and pressure.
Depending on the noise, it may just be the linings dragging or they are coming apart. Either way I would just take the drum off and inspect them. If they just need to be adjusted, you can do that by spinning the adjuster that I highlighted in the attachments.
If you can, get a recording of the noise so we can hear it and that may be able to tell us what it is.
WOLFC
  • 2004 PONTIAC VIBE
My rear drum will not come free. How do you get it loose? Any tips?
Wednesday, June 9th, 2021 AT 12:31 PM (Merged)
DEMERS669
Purchase two M8 1.25 x 40 bolts and screw them into the drum (there are 2 holes, 180 degrees opposite each other at the inner part of the drum). Using a socket, turn each bolt, alternating between the two and slowly turn the bolts clockwise. This will cause the drum to loosen up and come off of the wheel hub
