When braking I hear an air sound?
125,000 MILES • V6 • TURBO • 2WD • AUTOMATIC
MARY LENGYEL
  • 14 POSTS
I have a Buick GN 1986. Where I live it is very rural, so I hope to get an answer or help before I go to look for someone to fix the problem.
This past week when using the car when I put my foot on the brakes I heard a sound, I will say it sounds like there might be air in the lines. The brakes seem fine, and it only happens when you first use the brakes and then goes away until you step on them again. I have brakes and the brake light has not gone on. I hope you can give me some suggestions as to what it is. Thanks in advance. I can't send a video of the sound as I don't have a cell phone.
Oct 5, 2023 at 5:46 AM
  • 55,732 POSTS
This happens when the power brake booster goes bad.
1. Remove two nuts attaching master cylinder to brake unit, then position master cylinder away from brake unit with brake lines attached.
Caution: Use care not to kink or bend brake lines.
2. Disconnect vacuum hose from check valve. Plug vacuum hose to prevent dirt from entering.
3. Remove four nuts holding power unit to dash.
4. Remove retainer and washer from brake pedal pin and disengage pushrod eye or clevis.
5. Remove power unit from car.
Oct 5, 2023 at 6:01 AM
MARY LENGYEL
  • 14 POSTS
Thank you, I will copy this info and then find someone to do this.
Oct 5, 2023 at 7:25 AM
  • 55,732 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Oct 6, 2023 at 2:40 AM
MARY LENGYEL
  • 14 POSTS
Thank you so much, I will let the person who is helping me see this info. Again, thank you.
Oct 6, 2023 at 7:21 AM
