Brake fluid leaking
2006 FORD CROWN VICTORIA
160,000 MILES • AUTOMATIC
WROSELL42@YAHOO.COM
When I start the engine brake fluid spits out of the driver side tire. What is causing this?
May 1, 2017 at 10:10 AM
HMAC300
  • CERTIFIED EXPERT
  • 48,601 POSTS
check for a broken line/ caliper leaking etc. then have a mechanic scan for codes for an ABS problem and or in need of a brake job as pads may be worn completely out and caliper piston is going to far.
May 1, 2017 at 12:16 PM
