Brakes go to floor
1999 GMC SAFARI
17,800 MILES • AWD
JL FELONY
  • 9 POSTS
I replaced master cylinder and bleed all bleeders. why are the brakes still having problems? And there are no leaks in the line.
Jan 2, 2017 at 5:40 AM
HMAC300
  • 48,601 POSTS
it may be the ABS has air in it. if so a mechanic has to put a scanner on it to command open valves so it can be bled. you might try renting a power bleeder and bleeding system.
Jan 2, 2017 at 7:17 AM
