master cylinder has the front reservoir bone dry and the back one is over filled
140,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
JASONPYZO
  • 87 POSTS
the master cylinder has the front reservoir bone dry and the back one over filled. when I took the cap off fluid when all over the rags I put around it. I did a visual on all the lines and calipers and no leaks. Can the fluid in the master cylinder be blowing by the piston in there and pulling fluid from one reservoir to the other or might it be something else?
Dec 21, 2016 at 9:27 AM
  • 55,673 POSTS
Hey JASON,
Yes if the seals have gone bad in the master it will over fill the reservoir.
Here is a guide that will help you replace the unit.
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Please let us know what you find so it will help others.
Best, Ken
Dec 28, 2016 at 4:25 AM
JASONPYZO
  • 87 POSTS
Yeah I just went ahead and ordered a new master cylinder, plan to flush whole system with new fluid. What is weird is the brake light never came on with an empty reservoir. I guess maybe it wasn't low enough in the master cylinder to register. Anyway I appreciate the info
Dec 28, 2016 at 2:17 PM
  • 55,673 POSTS
Please let us know happens so it will help others.
Best, Ken
Dec 29, 2016 at 4:27 AM
JASONPYZO
  • 87 POSTS
absolutely, parts will be in in the next couple of weeks
Dec 29, 2016 at 4:58 AM
