Brake problems
1975 MERCURY COMET
67,899,165 MILES • AUTOMATIC
ASPENADMIN
  • 20 POSTS
By the way I have a second car. A dented car listed above. The brake pedal feels firm like is working normally but the car does not stop at all. Last time I wound up behind a brand new Ferrari and I had to back off because I was getting too close as I speeds through an intersection. It must have made the owner of that Ferrari very nervous to look in his rear view mirror and see me coming up fast driving a beat up, dented 1975 Mercury Comet barreling down behind him. My brakes was not good.
Jan 27, 2019 at 1:12 PM
SEVAG P
  • 405 POSTS
hi aspen.
it seems brake pads are too old dried out ,as a first step replace front and rear brake pads,check the rotors for rust , chips, lateral run out ,also check the brake fluid quality replace it if its dirty (black in color)or not replaced more then 2 years. check the guide: https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd.
Jan 28, 2019 at 2:28 AM
ASPENADMIN
  • 20 POSTS
When I was driving brake pedal was like this, firm but not slowing.
Jan 31, 2019 at 1:28 AM
SEVAG P
  • 405 POSTS
Hold pressure on the pedal while you start the engine.when the engine starts,the pedal should drop a 1/4",this indicates that booster is working properly.
1:if not remove vacuum line from the servo booster turn on the engine you must feel strong vacuum,check one way valve it must pass vacuum in one direction,if they are okay then brake booster defected.
2:if yes brake pedal drops,then brake pads are in bad condition bad quality,or too old)or hydraulic brake lines clogged,or it can be caliper pistons rusted and blocked.
Jan 31, 2019 at 2:07 AM
ASPENADMIN
  • 20 POSTS
Yes, the brake pedal drops.
Feb 9, 2019 at 11:58 PM
SEVAG P
  • 405 POSTS
Have you checked brake caliper pistons if they are working properly? or the brake pads if they are dried old.
If they are replace brake pads.
Feb 10, 2019 at 2:17 AM
ASPENADMIN
  • 20 POSTS
Brakes are old. I don't know for the piston.
Feb 28, 2019 at 2:35 PM
  • 55,421 POSTS
It sounds like you need to replace the master cylinder. here is a guide to help:
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Mar 4, 2019 at 2:45 AM
ASPENADMIN
  • 20 POSTS
How will master cylinder affects my brakes?
Mar 5, 2019 at 1:41 AM
  • 55,421 POSTS
if it is worn out it will internally bypass causing the low pedal.
Mar 5, 2019 at 2:13 AM
ASPENADMIN
  • 20 POSTS
Will my car stop?
Mar 5, 2019 at 9:56 AM
  • 55,421 POSTS
nope, I would not drive it.
Mar 6, 2019 at 6:32 AM
ASPENADMIN
  • 20 POSTS
I was driving and this happened.
Mar 6, 2019 at 11:29 AM
  • 55,421 POSTS
That brake pedal does not look like a 1975 Comet?
Mar 7, 2019 at 1:29 AM
ASPENADMIN
  • 20 POSTS
Oh sorry. I sent you the wrong video.
Mar 7, 2019 at 1:47 AM
ASPENADMIN
  • 20 POSTS
Will I be able to brake in time?
Mar 13, 2019 at 4:11 AM
