Brake pedal traveling to floor before and after master cylinder replacement?
72,500 MILES • 2.6L • V8 • 2WD • AUTOMATIC
DUSTYURNOT…
Replaced master brake cylinder all brake pads replaced, totally bleed system (x2, 2 quarts of fluid used) starting with rear right, r/l, f/r, f/l. No fluid leaks anywhere.
ABS dash light is not illuminated except for engine start up. ABS light does not illuminate when braking. Both low (5A) fuse and high (60A) fuses for ABS system tested good, removed and cleaned fuse contact blades to make sure conductivity was positive.
Is the ABS pump motor defective?
Am I missing something?
Is there a test procedure for the pump motor?
Nov 8, 2022 at 12:10 AM
  • 55,694 POSTS
Sure, so what happens is the ABS unit gets air trapped inside which causes the brake pedal to be low or to go to the floor. The ABS unit needs to be bled which requires the ABS control valves to be opened at the time of bleeding.
Here is a video and guide to help you fix the problem:
https://youtu.be/nQRnKyVyMuQ
and
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Let us know what happens and please upload pictures or videos of the problem.
Nov 8, 2022 at 1:28 AM
