Brake pedal slowly sinks when at a stoplight
155,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
ALGORITHM
  • 6 POSTS
When I have been driving the van, and come to a stop in "drive", after about ten seconds, the brake pedal slowly sinks, and lets the van move forward.
This van is a combination camper, work van, and daily driver, and has the Ford XLT package. It is garaged all the time, and looks new under the hood. I had an Auburn limited-slip differential installed in 2009, using the same OEM 3:55 gear ratio. The rear disc brakes were removed at that time, since the differential installers removed the housing to chemically clean out a lot of metal debris.
Back to the brake pedal, if I push further on the pedal, the van stops again, but soon the pedal begins sinking again, and the van begins creeping forward again.
If I pump the pedal two or three times, the pedal is firmer and higher again, but soon begins sinking when I am holding the van stopped in drive, such as at a traffic light.
An ASE certified mechanic, who has his own two man repair shop, replaced the master cylinder about eight months ago, and when I asked him if he had done any special procedure to bleed the ABS unit, he replied that no special procedure is necessary. Since then, I have heard a little about the need to bleed the ABS unit, using a special procedure.
For about a week after he replaced the master cylinder with a new Ford OEM unit, the pedal was very "normal" high, firm, no sinking.
After that week, over a period of a few days, the pedal gradually returned to its "sinking" ways, just like before the master cylinder replacement. That was eight months ago, and has been the same since, not getting any worse.
I have had the van since 2008, have had all the pads replaced in 2012, and at that time the front wheel bearings were lubed and adjusted, (still have plenty of pad thickness on them, I drive it very gently, brakes do not do anything else wrong, ABS system does seem to work reasonably well in snow), and have had the brake system flushed/filled at least twice since 2008.
The fluid level in the master cylinder never drops, and when examining under the van, I see no signs of brake fluid leaking anywhere.
Van has 155,000 miles on it now, had 92,000 when I bought it used in 2008.
Best regards,
Ed
May 8, 2018 at 11:54 PM
CARADIODOC
  • 34,413 POSTS
You already covered all the stuff I was going to discuss. It sounds like your new master cylinder is defective.
Your mechanic's comment about no special bleeding procedures required sounds correct as evidenced by your having a solid brake pedal for a week. Vans and trucks with rear-wheel ABS do not have any special procedures for bleeding. With four-wheel ABS, which is more common by 2004, some need a scanner to command the ABS computer to open two valves to allow two chambers in the hydraulic controller to be bled, but that has to be done with the two bleeder screws open at the wheels so the air can get out.
There is a simple trick when replacing a master cylinder that eliminates the need to bleed at the wheels, as long as no air has gotten into the lines. This is especially effective for saving time when the vehicle has a four-wheel ABS system that requires the scanner for bleeding. When calipers or wheel cylinders are replaced, it is standard practice to not allow the brake fluid reservoir to run empty when those parts are bled. That also insures no air can reach the ABS hydraulic controller, so again, no special bleeding procedures are required.
To address your slowly-sinking brake pedal, for it to do that, the brake fluid has to be going somewhere. Typically we think of a slow external leak, most commonly a leaking rear wheel cylinder. Calipers rarely leak. Rubber flex hoses normally burst, resulting in no brake pedal at all. Steel lines can rust through, but the slow leaks they cause usually turn into fast leaks pretty quickly. What all of these have in common is brake fluid is leaking externally and the level in the reservoir will go down. You have observed that is not what is happening. That only leaves internal leakage where the fluid is bypassing the seals in the master cylinder. When you push the brake pedal, after about the first inch of pedal travel, a port is blocked, then the fluid is trapped and has no choice but to be pushed down to the wheels. When one of the two seals leaks, that trapped fluid is able to sneak past it and go back into the reservoir. As it does, the brake pedal keeps going down slowly.
As a point of interest, this problem often occurs with older master cylinders right after the driver was surprised by a sudden leak, or by improper bleeding procedures. This does not apply to your van, and please do not blame your mechanic, but it is worth mentioning. After about a year, crud and corrosion build up in the lower halves of the bores in the master cylinder where the pistons do not normally travel. When you are surprised by a sudden leak, you end up pushing the brake pedal all the way to the floor, and that runs the two rubber lip seals over that crud and that can rip them. That results in the slowly-sinking brake pedal, like you have, and that often takes two or three days to show up. For that reason, when a shop gets a vehicle in for that leak, they will often include a rebuilt master cylinder in their repair estimate, rather than have to tell the owner later that more parts are needed. (We do not like having to do that).
This internal leakage is also often caused by do-it-yourselfers and inexperienced mechanics when they bleed the system with a helper pushing on the brake pedal. It is common for the helper to push the pedal all the way to the floor, and that is when the damage is caused. Professionals never allow the pedal to be pushed more than half way to the floor. In fact, most of us use gravity-bleeding. We do not use helpers or trust them with our jobs. Remember, this does not apply to your van because the master cylinder is too new. It still sounds like it is the same internal leakage that is occurring, but not because of anything the mechanic did wrong.
Here is an article that does a better job of explaining this problem:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
May 9, 2018 at 9:39 AM
ALGORITHM
  • 6 POSTS
Hi, and thanks for your quick and thorough reply . :)
After reading your reply, and after watching the video you recommended, I learned a few things:
1. the newly replaced, eight month old master cylinder could be defective.
2. from the video, it is possible that air is entering the system through any of the caliper seals, when the brake pedal is released and the calipers / pads are backing away from the rotors.
3. some vans/trucks have rear-wheel ABS, some have four wheel ABS.
4. even with four wheel ABS, there may be no need to use a scanner tool to auto-bleed the unit.
Some more information I would like to add:
1. my van has four wheel ABS.
2. the calipers and rotors may have never been replaced ( van had 92000 when I got it, and the dealer said that its history up to then was nearly all miles were on the interstate roads, over four years, in southern states, the pristine condition of the underside when I got the van, sort of supports that.
3. at present, the brake pedal sinks to more than halfway to the floor at times.
I am not really clear on what to do next, though.
I have been a bit interested in obtaining one of the Autel MaxiCheck Pro scan tools, to read PCM codes and do other tasks.
I understand it can do ABS auto-bleeding, too.
If I do replace the master cylinder again as a way to start, is there a particular brand that you most recommend ?
Best regards,
Ed
May 10, 2018 at 12:25 AM
CARADIODOC
  • 34,413 POSTS
No particular brand. All are of good quality or the parts stores would stop carrying them. You can run into one where a new, inexperienced person put it together and made a mistake, but that is not very common.
If you are going to do this yourself, here is a trick I use on my own stuff. When you replace the master cylinder with two steel lines, loosen the line nuts a little, remove the mounting bolts to the power booster, pull the master cylinder forward, then use it as a handle to bend the steel lines up a little. That will keep the fluid from running out of the lines.
Remove the two lines all the way, then remove the master cylinder. Brake fluid eats paint, so be careful to not allow any to drip onto the van.
Screw the two lines into the new master cylinder that has been bench-bled, then use it to bend those lines back down to their normal shape. Bolt it to the booster, then snug one of the line nuts. Have a helper slowly push the brake pedal half way to the floor. It should take about fifteen seconds to do that. You will see bubbles coming out by that nut. Snug the nut, then holler to the helper to quickly release the pedal.
Do that a second time, and perhaps a third time, until you see only clear fluid with no bubbles coming out, then do that for the other line. By pushing slowly, fluid will get pushed down the lines, and air will float back up. By releasing the pedal quickly, the fluid rushing back will wash the air back up into the reservoir with it. This can even work when working on the van by yourself, just keep the line nuts tight.
This wondrous trick might not work as well on Fords that have four lines at the master cylinder. What will happen is the air will bleed itself out to the reservoir if you give it enough time. Applying the brake pedal will not push air down the lines any further than you are going to be pushing brake fluid, so it will not get to the ABS hydraulic controller. All the air at the top of the lines will bleed into the reservoir in as little as a few pedal applications, or as long as a day or two. We cannot let a customer's car go that way, so we have to do this with the helper and opening the lines, but this has always worked for me when I am by myself.
May 10, 2018 at 7:52 AM
ALGORITHM
  • 6 POSTS
Hi everyone,
A while back, I replaced the master cylinder, as suggested, with a Raybestos unit from rockauto.com. The install went well, bench-bleeding was successful, but there has been no change from before, nor is it any worse.
Being in a quandary, I did happen on a 2014 YouTube video at this link.
https://www.youtube.com/watch?v=0r46_unyYk8
or
https://youtu.be/0r46_unyYk8
The video is describing internal problems that happen to the ABS unit, problems which don't trigger the ABS light on the dash.
One problem appears to originate in the ABS unit's pump/valve mechanism, and another problem seems to come from the controller which sits atop the pump unit.
This video may speak to the problem I am having.
Any thoughts on this?
Best regards,
Ed
Aug 15, 2018 at 12:41 AM
CARADIODOC
  • 34,413 POSTS
Interesting video. We talk about this possibility all the time, but it is not that common to see.
Aug 15, 2018 at 3:44 PM
