After losing the brakes I replaced the rear end all calipers all bled and now pedal sinks to floor
200,100 MILES • 5.4L • V8 • 4WD • AUTOMATIC
TIMOTHY MIISHAKWAD GAUTHIER
  • 5 POSTS
My dad drove this truck to my uncle's garage twenty miles. When he got there no brakes. before he drove it it had excellent brakes, but there was a leak. I replaced the rear end all calipers all bled and now pedal sinks to floor. No air come out when bled.
Dec 22, 2016 at 10:48 AM
CJ MEDEVAC
  • 11,000 POSTS
Was the master cylinder empty the first go round?
It is possible the master cylinder is shot, The plunger inside is no longer sealing on the cylinder walls and is allowing fluid to pass by instead of pushing it.
Seems everybody has a way to bleed the system, some effective, others just sort of winging it going off of hearsay.
I am pretty much old school and like carbureted stuff over the new high tech stuff.
I have found that pressure bleeding (link below) pushes the fluid and air out the fastest and more effectively, some think that gravity bleeding is the way to go. I have Jeeps and work on 4x4's. I disagree, as if your brake hoses are high (loops/ curls) the fluid does come out the bleeder, but the air rises to the top and does not "fall out" like the fluid. (sort of like your shampoo bottle turned upside down).
See my answers on the link below, this is the way I was taught back in the early 1970's, pretty much still works well on most vehicles.
https://www.2carpros.com/questions/1998-ford-f-150-cant-get-brakes-bleed
Keep us posted.
Merry Christmas!
The Medic
Dec 22, 2016 at 11:36 AM
  • 5 POSTS
I think it is because when i switched my front calipers the bleeder is at the bottom. would that be why?
Dec 22, 2016 at 11:38 AM
CJ MEDEVAC
  • 11,000 POSTS
I think you got it figured out!
Usually that kind of information is never given to us, they chase their tails forever.
Glad you threw it on the table, that is something I will try ask when someone else is having a hard time.
Did my shampoo bottle story make you think of that?
Correct it and return with some good news!
The Medic
Dec 22, 2016 at 12:02 PM
  • 5 POSTS
Actually yes it did help. lol, but tomorrow morning i am going to switch it.
Dec 22, 2016 at 1:46 PM
RENEE L
  • 1,260 POSTS
CJ MEDEVAC. Merry Christmas to you!
Dec 23, 2016 at 1:01 AM
  • 55,710 POSTS
FROM TIMOTHY MIISHAKWAD GAUTHIER
Ok thank you!
Dec 23, 2016 at 3:36 AM
CJ MEDEVAC
  • 11,000 POSTS
MERRY CHRISTMAS TO Y'ALL TOO!
YOU GUYS ARE SWELL!
TIMOTHY MIISHAKWAD GAUTHIER- still wanna hear the outcome!
The Medic
Dec 23, 2016 at 4:14 AM
  • 5 POSTS
Stiff pedal at bottom going to switch side for calipers for rear then ill let you know
Dec 23, 2016 at 5:36 AM
  • 5 POSTS
Can you help me with a different problem? Same truck
Dec 23, 2016 at 9:40 AM
CJ MEDEVAC
  • 11,000 POSTS
Normally they like a new question submitted.
This kinda separates the "problems" so that Joe Schmoe doing a 'search' will be able maybe 'relate' his similar problem with yours, hence, he may get his fixed from your "one" experience.
Nuthin' says you can't run two questions (threads) at the same time!
GO FOR IT! (new question)
The Medic
Dec 23, 2016 at 9:54 AM
  • 5 POSTS
Ok but foe the fact yes switching the calipers did help with pedal i do have brakes but not good so probably going to get a new master cylinder. Ok new thread
Dec 23, 2016 at 9:56 AM
  • 55,710 POSTS
Can you please start a new question on the site, we don't like to mx subjects up becasue Google won't know what we are talking about so it wont help others
Thanks! Ken
Dec 23, 2016 at 2:43 PM
