brake pedal going to the floor and staying down
170,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
OXCARTMAN AND WIFE
We replaced the master cylinder due to internal leak on old one. The brakes were very soft and no fluid in reservoir. after we checked lines and wheels and saw that they were not wet, so put on new master cylinder. Did bench bleed before installed and bled at wheels. Now when you push the brake pedal it goes to the floor and stays there will not come back up. You cannot pull it up. It will only come up if you turn off the vehicle or unhook the vacuum line on the brake booster. The brake booster has strong vacuum. What could be causing the brake to stay down?
Apr 2, 2018 at 11:44 AM
STEVE W.
  • 15,409 POSTS
Well the description sounds like the master cylinder you have is the wrong one. There are a couple different ones out there and they use different length apply rods from the booster. Using the wrong one lets the booster apply valving stay on and it applies vacuum regardless of the pedal position. It also sounds like you have the typical GM brake issue where you need to bleed the brakes two to three times to actually get all of the air out of the system, especially the ABS unit. I would suspect there is air in the lines. These guides can help you fix it.
https://youtu.be/w7gUsj2us0U
and
https://youtu.be/WDxvEQrMkBg
and
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Apr 3, 2018 at 5:57 AM
