Brake pedal goes to the floor
200,000 MILES • 4 CYL • FWD • AUTOMATIC
SAMLAVITE
Hello, here is my problem. There is no brake or ABS light on in the dash. I have replaced the brake booster and master cylinder and I have tried to bleed the brakes but only the front right and rear left calipers have just enough pressure to be bled but the other two don't and I cannot get any fluid to come out. Thanks!
Nov 11, 2016 at 3:58 AM
HMAC300
  • 48,601 POSTS
have a mechanic with a scanner that can open the valves on the ABS unit bleed the system this happens a lot when a diy person tries to bleed brakes. Pretty much this is the only way you can bleed it successfully unless a power bleeder gets it done for you, but normally it wont.
Nov 11, 2016 at 4:07 AM
SAMLAVITE
Dang brother. Thank you!
Nov 11, 2016 at 4:27 AM
  • 55,500 POSTS
Please use 2CarPros anytime, we are here to help and tell a friend.
Best, Ken
Nov 16, 2016 at 7:06 AM
