Brake pedal
133,691 MILES • 3.5L • V6 • 4WD • AUTOMATIC
HUGGIEBEAR312
  • 25 POSTS
Brake pedal gets hard to press sometimes. I took it to have an oil change they check the brakes and now my brake pedal is hard to press. it does not happen all the time just sometimes. I have checked the brake fluid and it is fine. what would cause this?
Dec 5, 2017 at 11:06 PM
  • 110,248 POSTS
Since it only happens at times, it may be vacuum related. The brake power assist booster may be losing vacuum or there may be a leak in the system. Watch this guide on how to find vacuum leaks. If there are no leaks, I would recommend testing the booster itself to see if it will hold vacuum.
Dec 6, 2017 at 11:56 AM
HUGGIEBEAR312
  • 25 POSTS
Thank you. I am also hearing a hissing noise when I am pressing on the brake.
Dec 6, 2017 at 11:57 PM
  • 110,248 POSTS
Most likely it is the booster. Check to see if it will hold vacuum.
Dec 7, 2017 at 10:07 AM
HUGGIEBEAR312
  • 25 POSTS
Okay, will check the booster and get back with you.
Dec 7, 2017 at 2:34 PM
