First the good news. It is likely brake fluid has leaked out from the rear brakes. You'll find evidence of this by seeing wetness in the inside sidewalls of the rear tires, and possibly small puddles on the ground, just inside the rear tires. Rear wheel cylinders have a tendency to leak, so there's "residual check valves" in the lines going to the rear brakes that keep a small amount of fluid pressure on the rubber lip seals. That keeps the seals pressed against the wheel cylinder housing so they seal better. That residual pressure can bleed down over time, then changes in barometric pressure can let those seals seep a little fluid. It is common for the fluid to leak only long enough to empty the brake fluid reservoir, but not the lines leading from it. That's the good news I'll elaborate on in a minute.
On most cars since the early '90s, there are three switches that turn on the red "Brake" warning light. One is on the parking brake pedal. Another is the "pressure-differential" switch which activates when the two halves of the system don't build up pressure equally, typically due to a leak. The one in question here is the "low brake fluid" warning light. That is the only switch that will turn on just by turning on the ignition switch, before you press the brake pedal.
Here's a link to an article related to this:
https://www.2carpros.com/articles/brake-system-warning-light-on
The place to start is by checking the brake fluid level and adding clean, new brake fluid if necessary. Do not fill the fluid to the top of the reservoir or even to any "full" mark you might see. At the mileage you listed, filling the reservoir half to three quarters full should be sufficient. I'll explain why we never fill it to the top later, once we have this solved.
Once the fluid is around half full in the reservoir, the red warning light should turn off. If it does, we will know for sure the low fluid was the cause. Now we have to address the low brake pedal. Air has gotten into the lines, and since air can be compressed, that is why the brake pedal could be pushed too far. Many people bleed that air out at the wheels, but that takes a long time and a lot of wasted brake fluid. More on this later too.
Since this problem usually leaves the lines full of brake fluid and no air, it is only the air inside the master cylinder that has to be expelled. One way to do that is to slowly press the brake pedal about a quarter way to the floor, wait a few seconds, then let it rapidly spring back up. By pushing it slowly, you'll push new brake fluid into the lines while giving the trapped air time to float back up. Pushing the pedal should take a good 10 to 15 seconds. By letting it pop back up rapidly, some of the air still in the lines will wash back up into the reservoir with the brake fluid that's rushing back. Very often you only have to repeat this a few more times before the pedal feel returns to normal. Any little air bubbles still trapped will wash back while you're driving. That air will not go down toward the wheels. That's why it is usually not necessary to bleed at the wheels. Once you get a good pedal, that residual pressure will have been developed, so everything will be back to normal.
Now for the bad news. Based on the age of the car, there is a very good chance you caused a second problem when you pushed the brake pedal all the way to the floor. There's two "bores", or cylinders, where the pistons travel that are pushed by the brake pedal. Since you normally only push the pedal no more than half way down, those pistons don't travel in the lowest parts of those bores. As a result, it is common for crud and corrosion to develop in those lower halves. The upper halves are the only areas you use, so the rubber seals riding there keep those areas clean. Now, when the pedal gets pushed more than half way to the floor, the rubber seals get dragged over that crud, and that can rip them. This can happen when a driver is surprised by a sudden leak, or when someone uses a helper to "pedal-bleed" the system, and that helper pushes the brake pedal more than half way to the floor. When a car comes in with a brake fluid leak, we often include a new master cylinder, along with the other needed parts, in the repair estimate, so we're covered if we do find a new master cylinder is needed. Sometimes it looks like the old master cylinder will be okay, but very often the internal leakage from ripped seals takes two or three days to show up. It will cause a slowly-sinking brake pedal when you hold steady, moderate pressure on the pedal.
Here's a link to an article that elaborates more on this issue.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
When you add brake fluid to the reservoir, it is critical that it be from a clean, sealed container, and there must be absolutely no hint of any type of petroleum product that gets in with that brake fluid. Even one drop of engine oil, transmission fluid, axle grease, WD-40 or other penetrating oil, or power steering fluid will melt the rubber seals. The only proper fix for that is to flush the steel lines, and replace everything that has a rubber seal or part in it that contacts the brake fluid. That can easily turn into a repair that costs more than the car is worth. Also, brake fluid loves to absorb moisture from the humidity in the air. That's why it's important to keep containers sealed. Moisture in the brake fluid promotes corrosion of metal parts. Since some of that moisture can't be avoided completely, that is why that corrosion builds up inside the master cylinder. Besides that corrosion, brake fluid boils at well over 400 degrees, but the moisture lowers that to near 212 degrees. Very often you won't notice that, but it's not that uncommon for brake parts to become hot, then that heat transfers into the brake fluid which can reach temperatures high enough to boil that water and turn it into a vapor that can be compressed. That leads to one type of brake fade where the brake pedal becomes mushy and goes too far to the floor.
While it does take a lot longer to bleed the system at the wheels, one advantage of doing so is it can remove most of that moisture-laden brake fluid. Every manufacturer recommends doing that at some interval, but very few of us actually do it because these systems cause such little trouble, we tend to forget about them.
Let me know what you find with the brake fluid level.
Nov 6, 2019 at 9:18 AM
