bleeding and brake fluid change instructions and seen many videos
68,000 MILES
FREESTEAMIN
I have read many brake bleeding and brake fluid change instructions and seen many videos. I am curious why none of them mention keeping the caliper compressed on each wheel in turn when doing a brake fluid change.Without keeping it compressed most of the old fluid will stay in the caliper which is exactly where you don't want old, burned, moisture laden fluid. Seems like a logical thing to do but there must be a reason why it is not mentioned. Is it because it would take more time?
Apr 27, 2020 at 1:50 AM
  • 110,248 POSTS
The fluid in the caliper will come out regardless. When you flush the system, you are removing everything. When you are bleeding at the caliper, simply make sure the fluid is clean before you finish.
Take a look through this link and let me know if anything helps answer your questions:
Here is a video and guide below to help you bleed the brake system correctly.
https://youtu.be/w7gUsj2us0U
and
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
and
https://youtu.be/WDxvEQrMkBg
Please run down these guides and report back. Let me know if you have other questions.
Apr 27, 2020 at 3:40 AM
