Bore specs and piston weight
140,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
CAMAROCAM27
Wondering what should i ask when i take the block to be bored and honed and what weight I'm looking for the pistons to be.
Oct 11, 2021 at 10:00 AM
  • 110,248 POSTS
I'm not sure I understand. Are you having the engine bored to a larger size? If that is the case, there are specific specifications they can bore to. As far as piston weight, I've never had that asked before. Can you explain?
Thanks,
Oct 11, 2021 at 1:53 PM
CAMAROCAM27
I'm going off the video series (Building 5.3 LS) by Ryan from 2CarPros. I'm going part by part with the series and i just need to know what i ask for as how much i need to bore the block to and what is the desire weight of the piston rod arms?
Oct 13, 2021 at 3:04 AM
RYAN L
  • 273 POSTS
Hey there!
Thanks so much for watching our LS series on YouTube. So, for bore size I would ask the machine shop what the block is going to clean up at, you are hoping for .030 over bore. Also have them check the block with a magnaflux process to ensure the block is usable. As for the connecting rods and piston weights go, you just want each piston and rod combo to be identical with weight to every other pair.
You will also have to get pistons and rings to match how ever much you need to bore your engine over to.
Thanks for using 2CarPros!
If you have any other questions, please let me know and I will help you.
Best regards,
Ryan
Oct 13, 2021 at 10:03 AM
