1998 BMW Z3 Clutch
82,000 MILES • 6 CYL • 2WD • MANUAL
STUPOT52
Needed to use the clutch alot in icy conditions recently...now I get a rattle noise when the clutch is engaged. My brother believes it could be a loose cable or lack of fluid...Any ideas?[img:fbf48c8d51]http://www.2carpros.com/forum/automotive_pictures/320855_P8170001_2.jpg[/img:fbf48c8d51]
Feb 20, 2009 at 8:51 AM
DOCHAGERTY
  • 9,606 POSTS
The clutch throw out bearing can make that noise. I also wish to say that noises are difficult to properly diagnose from cyberspace and you may wish to get the opinion of a knowledgeable BMW tech who can be there with you to hear your noise and give you an honest, close-up opinion. When you disassemble the car to repair this issue, be sure to inspect the flywheel and replace the pivot pin.
Feb 20, 2009 at 11:17 AM
