1997 BMW Z3 Vibration upon acceleration, primarily low gear
NEOCLICKNCLACK
  • 6 POSTS
Drive Train Axles Bearings problem
1997 BMW Z3 4 cyl Two Wheel Drive Manual
So I have the aforementioned vehicle and its making a pretty hard vibration when acceleratiing. I have an idea of the source, but Im not positive and just want to get some feedback, hopefully someone can reference some nice online material that i can review. The sound is a knocking like sound that seems to be originating about mid way underneath the car. I have not looked under the car, but suspect there is a drive axle coupling there and some part of that couplling is going out. I used to have a 1976 FIAT 131S and it was notorious for that issue and it pretty much sounds the same. So assuming Im on the right track, Id like some feedback on how tough a job it will be, maybe some things to check for to verify, the right scope of repair and parts replacement, expected cost and time frame and whatever else you think appropriate. Seeing a video online for the repair scope would be awesome. Thanks
Dec 31, 2008 at 11:37 AM
DOCHAGERTY
  • 9,606 POSTS
The vibration is most likely caused by a driveshaft center support bearing carrier is ripped and will require replacement, perhaps a new or rebuilt driveshaft. The cost should be available online for the parts at Realoem.com. Allow 3 hours to perform this repair.
Dec 31, 2008 at 4:15 PM
NEOCLICKNCLACK
  • 6 POSTS
About what i expected. Ive never done this type of repair though but I guess first time for everything. I see about $75 for the support with bearing. Hopefully I wont need the drive shaft itself. Now I just need to find some instructions. I ordered a CD based manual, but it hasnt shown up yet.
If anyone has the pages for the repair, Id certainly like to receive them asap.
I will likely try to document the repair by video and upload for others to use.
Dec 31, 2008 at 4:30 PM
DOCHAGERTY
  • 9,606 POSTS
The repair is not complicated. Remove the exhaust and the heat shielding to access the driveshaft. When reinstalling remember to preload the center support bearing 6mm to the front.
Jan 1, 2009 at 1:15 PM
