Running too rich (too much fuel, not enough air)Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
SPONSORED LINKS
Wednesday, June 24th, 2009 AT 1:10 AM
