2001 BMW X5 Transfer box chain jumping?/
GEEWISS
  • 2001 BMW X5
  • 6 CYL
  • 4WD
  • 20,000 MILES
Noise when under load, sounds like chain in transfer box jumping teeth. I have heard they do this as there is no tensioner?
can you advise what sort of job it is?
Thanks. Graham west
Sunday, September 7th, 2008 AT 8:29 AM
DOCHAGERTY
  • 9,601 POSTS
As you refer to the job, do you mean inspecting for the cause or repairing the issue? Inspection would start with draining the oil from the transfer case and seeing if there is contamination in the oil. Repairing the unit might be as straightforward as replacement of the entire transfer case, and possibly less costly. If replacement sounds like the path of least resistance then call (619)444-2290 for Autobahn dismantling and talk to John or Sean.
Sunday, September 7th, 2008 AT 9:26 AM
GEEWISS
Thanks so much for the help you gave. Are Autobahn dismantling in Germany? I live in Spain.
Thanks Graham West
Sunday, September 7th, 2008 AT 1:29 PM
DOCHAGERTY
  • 9,601 POSTS
I apologize for my ignorance, as a moderator I may have made an assumption that your question was generated from somewhere in the United States. I do not know of any place in Europe that you could source the part you need. The E-mail address for Autobahn dismantling is parts@autobahnparts. Com and they are located in the USA in El Cajon California @ 444 Vernon way zip code 92020
Sunday, September 7th, 2008 AT 2:09 PM
Related General Content
