2001 BMW X5
YAS
  • 2001 BMW X5
  • 6 CYL
  • AWD
  • 79,000 MILES
Hi, i've got bmw x5 and the problem with the car is misfiring everynow and then. When this occurs the accelerator pedal gets stiff and is like something holding back when try to kickdown. Sometimes the engine sound heavier than normal. Can pls help. The engine check light was on but after diagnose it was switch off. I can tell the engine is not function well
Thursday, February 25th, 2010 AT 1:53 PM
DOCHAGERTY
  • 9,601 POSTS
Is the issue with the accelerator pedal that it actually feels stiff? Do you have carpet or trim in the way? There shouldn't be any issue with the gas pedal at all since that car is fly by wire, just two potentiometers reading in opposite directions for plausibility. Is the check engine light on?
Friday, February 26th, 2010 AT 8:58 AM
