2004 BMW X3 Rear window does't go down
GAMMAMAN
  • 2004 BMW X3
  • 4 CYL
  • 40,000 MILES
Motor makes sound but window does not go down.
How do I remove door panel to check regulator?
Thanks
Friday, March 13th, 2009 AT 3:40 PM
DOCHAGERTY
  • 9,601 POSTS
There are several Torx screws holding the panel on. Look under the arm rest and behind the plastic plug that has "SRS" embedded in it. After the screws are out then starting at the bottom with a plastic wedge tool, pop the panel loose. Pull on it and you will unclip the plastic anchors, it requires some force. Then pull up and away with the panel.
Friday, March 13th, 2009 AT 8:24 PM
