1973 Other BMW Models smoke problem
1973 BMW
RAIMOND_1
Engine Mechanical problem
1973 Other BMW Models 6 cyl Four Wheel Drive Manual change miles
hi
i bought a car.thats worked good with out any problem.
i parked it for 1 week & did the carburetor work & ignition system.
after one week when i started the engine ,car was run good,but when the engine went to normal operating temperature ,started the smoking.
the smok is blue same as oil burning.
on cold temperature it doesn't smok.
i asked to my mechanic and he told me the problem is maybe the valve stem seal and they are damage.
could you please help me.because different people told me different things.i need the true answer.
thanks & best regards
Jan 18, 2009 at 5:48 PM
DOCHAGERTY
  • 9,606 POSTS
The smoke would seem to indicate that there is an issue with oil control, I would tend to side with your mechanic about the valve stem seals and possibly the oil control past the rings as well.
Jan 19, 2009 at 3:22 AM
RAIMOND_1
thank you .tomorrow i'm going to change the valve's seals.ofcourse i will tell about what happend.
Jan 19, 2009 at 5:12 PM
DOCHAGERTY
  • 9,606 POSTS
Good luck mate. ♥
Jan 20, 2009 at 1:12 AM
