1970 2002tii Gas Gauge Stays At Full
1970 BMW
ATTPHONEMAN
The needle stays at full. I bought a new sending unit and it still reads full at all positions. When I disconnect the tan sending wire, it goes to empty (like it's supposed to). When I hook up a new VDO gauge, it reads 1/2 at empty and OVERFULL at the full position.
Is there a voltage limiter or regulator which lowers the voltage (or amperage) to the gauge that is shorted across?
Or is there another problem?
Oct 13, 2007 at 7:19 AM
I'll start at the voltage limiter
Oct 13, 2007 at 8:39 AM
DOCHAGERTY
  • 9,606 POSTS
The 2002 problem you describe here will most likely require replacement of the instrument cluster. Seek out a salvage shop that does `02's (double 02 salvage or La Jolla Independent)
Nov 17, 2007 at 2:28 AM
