1991 BMW M5 Check engine light at idle after long trips
1991 BMW M5
181,000 MILES • 6 CYL • 2WD • MANUAL
PIANCU
Hello. After I drive my car for a long trip (80+ miles), the check engine light will come on with a code of 1221 (oxygen sensor) when the car is at idle, such as at a stop light. Once I start moving again, the check engine light goes away. I have a new water temp sensor, oxygen sensor, MAF and vacuum hoses. Why is this happening only at idle after long trips? Does not happen in city driving.
May 14, 2010 at 11:53 AM
DOCHAGERTY
  • CAR REPAIR CONTRIBUTOR
  • 9,603 POSTS
Was the Oxygen sensor a Bosch direct replacement?
May 15, 2010 at 9:14 PM
PIANCU
No, it was a Denso oxygen sensor. It has 10k miles on it.
May 17, 2010 at 6:53 PM
DOCHAGERTY
  • 9,603 POSTS
There might be an issue with the Denso part. The system was built for a Bosch sensor.
May 18, 2010 at 9:37 AM
