2003 BMW M3 Can't pass smog check in California
82,000 MILES • 6 CYL • 2WD • AUTOMATIC
LEXESTY
My BMW M3 has high HC (hydrocarbons) at
15mph measured 98 and the Max is 51,
25mph measured 77 and the Max is 35. I have done the tune-ups and oil change. The CO% and NO(ppm) passed without any problems. How can I bring down the HC reading? Does that mean my cats are bad?
Thank You!!
Nov 21, 2009 at 5:44 PM
  • 75,988 POSTS
Hydrocarbon failures mean unburned gasoline is passing through the engine and entering the exhaust. The three most common causes include ignition misfire, lean misfire and low compression (typically a burned exhaust valve). Ignition misfire can be caused by worn or fouled spark plugs, bad plug wires or a weak coil. Lean misfire results where there is too much air and not enough fuel, so check for vacuum leaks, dirty injectors or a fuel delivery problem. In addition to these, hydrocarbon failures can also be caused by oil burning due to worn valve guides, valve guide seals and/or rings.
Nov 21, 2009 at 6:28 PM
LEXESTY
So, my cats should be in a working condition, correct? Will the HC be reduced if the old cats are replaced?
Thanks Again!!
Nov 21, 2009 at 7:18 PM
  • 75,988 POSTS
That's the Cat's job is to lower the HC/CO
Nov 21, 2009 at 8:25 PM
