2001 BMW E46 Rear Noises
KAYUKI07
Noises problem
2001 BMW E46 4 cyl Automatic 180000 miles
Ive been getting noises from the rear everytime i press the pedal. The noise would usually start when passing the 90km but when released, the noise goes away. when pressed again, it comes back. Some say i need to change my axel but i would like some second opinion on my problem. thanx.
Sep 4, 2009 at 4:18 AM
DOCHAGERTY
  • 9,606 POSTS
Noises are not easily transmitted in cyberspace, if you could help me out I can try to distinguish what the noises are and/or what is causing them. What does the noise sound like and exactly where is it coming from? From the rear is generalizing, which side? Is it a growl or a vibration or a groan or a squeak or some other term that could help.
Sep 5, 2009 at 4:11 AM
KAYUKI07
Sorry bout that. I would say its, more of a humming sound increasing as it passes 90kmh. the sound is coming from the rear/aft leftside, i would say. i've added oil as a first step but the sound is still there. checked the bearings, its ok. Still in good condition. problem still not solved.
Sep 5, 2009 at 9:18 AM
DOCHAGERTY
  • 9,606 POSTS
Added oil to what? This could be chalked up to tire noise for all I can tell. What method was used to remove the wheel bearings from suspicion? Has the drive shaft been inspected? I am at a loss.
Sep 5, 2009 at 5:29 PM
