2001 BMW E46 Oil in water bottle
175,000 MILES • 4 CYL • 2WD • MANUAL
HANSIE
Can you Guys help me, I have a BMW 320D, 2 Days ago i started the car in the morning, wasn't cold but the car struggled to start.eventually it started, after a drive i got home & wanted to wash the motor, opened the water bottle to check water level & found Black oil in the water. thought it could be Head gasket but the car doesn't loose power or get Hot, when i removed the dipstick the oil is still original colour & no water inside motor. there is some white smoke coming out under car, i thought it could be the Intercooler loosing oil in cooling system but not sure. what could be the problem??
Nov 2, 2009 at 3:19 PM
DOCHAGERTY
  • 9,606 POSTS
Possibly the heat exchanger. The Diesel E46 never made it state side so this information may need a bit of research, I will get back tonight, BTW, I am in California.
Nov 3, 2009 at 1:21 AM
HANSIE
Thanx Dr. Hagerty, i'm in South Africa. One of my Friends told me he thinks it could be a oil port that blew it's way to a water port. Well the car doesn't get hot & doesn't loose power. He opened the oil cap & said the commpression in the motor is to high, looks like steam coming out of motor.
Nov 3, 2009 at 2:36 PM
DOCHAGERTY
  • 9,606 POSTS
Something may have compromised the head gasket, or it has some issue with the head to block sealing.
Nov 3, 2009 at 2:58 PM
