1990 BMW 750Li Auto leveling shock
1990 BMW 750LI
140,000 MILES • V12 • 2WD • AUTOMATIC
LCOMER72
  • 14 POSTS
My passenger rear shock is leaking and I was wondering if it could be repaired or do I need to replace it? If it needs to be replace, do you know of a place where I can find a good used or rebuilt auto leveling shock? Would I need instructions to install this parts or is it as easy as installing a normal shock?
Nov 1, 2010 at 7:32 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The shock will need replaced with either a new or used unit. You should check websites such as ebay.com , used-car-parts.com and craigslist.com out for used parts. If you would like replacement steps just let me know, it is a bit different than a regular shock.
Nov 1, 2010 at 3:16 PM
DR LOOT
  • 2,311 POSTS
this is a very common problem, I doubt you will be able to find used ones because they will be bad also, new ones will cost a fortune, what I usually do is replace them with 735IL BMW coil overs available very cheap at the junkyard and plug off the hydraulic line to the shock.
Nov 1, 2010 at 3:56 PM
