2001 BMW 740 BMW Repair
128,000 MILES • 6 CYL • AWD • AUTOMATIC
IRENE YOUNG
I'm having a problem wkith my steering wheel not turning. The car will turn on ok but no steering, it moves but no steering. I have no warning light indicator therefore I'm totally clueless. I checked under the hood and found that a belt around the fan/alternator (?) was stripping and the fan/radiator was very, very loose. What would cause this type of problem and what do you think the problem is?
Jun 29, 2008 at 11:02 AM
DOCHAGERTY
  • 9,606 POSTS
Your description sounds like the multi groove belt has worn out and will require replacement. As to the loose radiator, I am unsure of the reason but you might need to seek out local professional assisstance to remedy the problem.
Jun 29, 2008 at 11:54 AM
