1998 BMW 740 transmission won't shift
1998 BMW 740
278,000 MILES • V8 • 2WD • AUTOMATIC
JACOB FROESE
I took the trany off to repair a coolent leak between the engin and transmission and after putting everything back together the transmission won't shift unless I drive it very aggresive, I can shift in manual .I used a scaner and it comes up with a code p0720 out put sensor .How hard is that to replace? and do you have any other ideas what to look for?
Thanks for your Help
Jake
Feb 25, 2009 at 1:08 AM
DOCHAGERTY
  • 9,606 POSTS
It is going to take dropping the pan(save the oil) to access the output speed sensor, part # 24-34-1-218-551, get a gasket and a filter too, and a little of the very expensive tranny fluid to top it off. I have also seen the wiring harness give problems, part# 24-34-1-423-719.
Feb 25, 2009 at 1:22 AM
DR LOOT
  • 2,311 POSTS
With all due respect to Dr Hagerty, I would advise you to check the loom to the transmission make sure you did not pinch it between the transmission and the engine, or damage it in any way, also check the plugs make sure you did not damage them, or push the pins back inside the plug.
Feb 26, 2009 at 5:20 PM
DOCHAGERTY
  • 9,606 POSTS
Excellent point Dr. Loot, I agree and thank you for the respect.
Feb 27, 2009 at 12:14 AM
