1998 BMW 740 fail safe mode
140,000 MILES • V8 • 2WD • AUTOMATIC
RGM172
i have a 740 il automatic tranny the fail safe tranny code comes on when the tranny slightly slips second gear going to third id i drive it carefully it doesnot do it but put your foot alittle into and it will go into failsafe mode,had a tranny pro check care but he says needs tranny,, and didnt want to pull pan to check fluid and filter says that wount happen with bad fluid or filter,, being a mechanic myself i am very scepticail of the diognosis without pulling pan and filter,, the car drives to good...
Jul 31, 2009 at 10:41 AM
DOCHAGERTY
  • 9,606 POSTS
It could easily be a software issue and you may need to obtain proper scanning to uncover the fault, do you have access to a GT-1?
Aug 1, 2009 at 11:39 AM
RGM172
no i only have the modis and solis snapon scanners i belive your talking about bmw scanner,,,
Aug 1, 2009 at 12:14 PM
RGM172
i donated $25.00 to your forum and all i get is a one line answer that means nothing,, what a racket you have i want to get in on this with my appliance bussiness for a donation i can give no help exept to suggest to donate more money, what does it take,,,very disapponted with your level of info.my neighbor the builder could have told me this info infact he did.maybe im not waiting long enough for another reply 4 to 5 days,,,,thanks for nothing bob & ken
Aug 4, 2009 at 10:46 AM
DOCHAGERTY
  • 9,606 POSTS
So instead of answering my question you just go and try to make me wrong, how interesting.
Aug 16, 2009 at 4:48 AM
RGM172
i did answer your question and asked another along the way with no response from you,, i only have accsses to snapon scanners,, i dont know what the gt-1 is and thats the other question,is it a bmw scanner, i was expecting more conversation back and fouth for the donation and thats why im slightly confused if i knew about one line answers i would have given much less per answer,,,so whos really confused here,,, me or you?
Aug 17, 2009 at 12:55 PM
DOCHAGERTY
  • 9,606 POSTS
Lets not get into a pissing contest. If there is one thing that modern BMW owners should all be educated on is the fact finding process that usually involves the proprietary software that the dealer uses to diagnose the car. If you have no knowledge of said software, then you are probably not going to get the information that will be required to make a proper diagnosis and repair. Aftermarket scanning equipment is sketchy when it comes to defining what to do with BMW transmissions. By assessing faults and reading live data and comparing this to what a normally operating transmission should do is a big part of what may well be needed to trouble shoot and repair the box on your BMW. How shall we proceed from here?
Aug 17, 2009 at 1:52 PM
BEAMERSSS
I own the same vehicle. The problem I found with my vehicle when I experianced the same problem was the switch on console. Sometime while driving on freeway it would go into fail safe mode. I changed switch in center console and i've been driving car over two years.
Apr 28, 2010 at 2:39 AM
