Could a bad transmission selenoid cause the engine to stall when put in reverse? Drives fine going forward.
Apr 5, 2010 at 10:34 AM
DR LOOT
✓Experienced Mechanic
if that is the case, you will need to take it to a transmission shop because you do not have the special scanners to communicate with the transmission.
Apr 6, 2010 at 10:50 AM
SHARLEEN
MEMBER
Thank you!
Apr 6, 2010 at 11:29 AM
