1998 BMW 540i bank 2 misfiring
84,000 MILES • V8 • 2WD • AUTOMATIC
GOOSE1207
I replaced my valve cover gaskets this past summer because of oil leaking into the plug wells. I recently replaced all 8 spark plugs as well. Using the Peake code reader, the codes I am getting are "misfire detected, cyl. 5" & cyl 6, 7 & 8. Additionally, there is a "random or unknown cylinder" misfire along with "catalyst damaging" on cyl 5, 6, 7 & 8. I've swapped the ignition coils & the misfires are still on cyl 5 - 8. Also, the pre-cat O2 sensors were replaced about a year ago.
The check engine light flashes during wide open throttle beyond 3000 rpm & it struggles to rev past 4000 rpm - I took my foot off the accelerator after a while, thinking that I might do more damage if I tried to push it beyond 4000 rpms.
Thanks in advance.
Dec 29, 2009 at 12:17 PM
DOCHAGERTY
  • 9,606 POSTS
A flashing check engine light is not good. It indicates cat damage is occuring. Tell me all that has been done to the car, I need to know if the intake manifold has been off and if the PCV plate is original.
Dec 30, 2009 at 5:55 AM
GOOSE1207
The intake manifold hasn't been off & the PCV plate is original. I'm assuming that the PCV is the same thing as the CCV? Do I need to replace the vacuum lines & rear intake manifold gaskets? How much time is required for a weekend mechanic to do this?
Jan 2, 2010 at 10:18 AM
DOCHAGERTY
  • 9,606 POSTS
The job can sell for 5 or 6 hours and what will need to be replaced is not clear from cyberspace, but it might mean everything.
Jan 2, 2010 at 3:46 PM
