Hi All,
I have recently changed the gas type for the A/C and done the conversion to latest technology (environmentally friendly).
Now the gas is leaking over 3-4 months to empty and I have been told to change the O-ring seals on the regulator valve of the evaporator.
Problem is to get the valve out as the piping is very tight and one clamp seems to be bolted in place from outside the fire wall (only accessible through opening under wipers but nor even visible)
Is there another means to remove the valve to enable the change of the correct seals (O-rings).
Thanks for details.
Walter
Thanks for details.
Walter
Nov 30, 2009 at 2:32 AM
