1987 BMW 535i ABS brake sensors
1987 BMW 535I
TBRADFORD
Brakes problem
1987 BMW 535i Two Wheel Drive Manual
How can I check the anti-lock brake sensors on this car to see if they are bad? Iread an article where someome checked them with a multimeter but it wasa a newer model than this one. Can I use the same procedure on this model?
Jul 10, 2010 at 2:27 PM
DOCHAGERTY
  • 9,606 POSTS
hat is the root problem?
Jul 10, 2010 at 5:27 PM
TBRADFORD
the antilock system is pulsating the brake pedal just before the car comes to a complete stop.
Jul 12, 2010 at 9:04 AM
DOCHAGERTY
  • 9,606 POSTS
The brakes may not be the problem, maybe the thrust arm bushings require replacement. See here: http://www.realoem.com/bmw/showparts.do?model=DC74&mospid=47231&btnr=31_0013&hg=31&fg=05
#6 is the part.
Jul 12, 2010 at 11:04 AM
