2000 BMW 535
2000 BMW 535
136,000 MILES • V8 • 2WD • AUTOMATIC
CUSHMAN31
Im looking for the correct procedure to replace the alternator in a 2000 bmw 540i, any help would be great.
Apr 18, 2008 at 3:15 PM
DOCHAGERTY
  • 9,606 POSTS
In order to correctly assist you, I will need to know the vehicle identification number as there are two types of alternators for this body style, one of them is air cooled and the other is liquid cooled.
Apr 19, 2008 at 4:00 AM
CUSHMAN31
Mine has the water cooled one
Apr 20, 2008 at 6:08 PM
DOCHAGERTY
  • 9,606 POSTS
First, this should be done on a cool engine due to the risk of scalding, as the cooling system needs to be drained. Remove the fan impeller and fan clutch with a 32MM fan wrench (left hand thread) release the tensioner bolt (pop the cover off to access the bolt head, it's a Torx T-60) and lay the tensioner roller to one side, remove the bolts retaining the alternator and remove the electrical connections, disconnect upper radiator hose to ease removal. A residual amount of coolant will be present when the alt. is removed. Also, disconnect the battery before repairs are attempted.
Apr 21, 2008 at 1:06 PM
