1988 BMW 535 Transmission Light Came On
GISLOC
  • 34 POSTS
Transmission problem
1988 BMW 535 6 cyl Two Wheel Drive Automatic 235*** miles
My transmission ligth came on....wouldnt shift out of 1st i think because it was taking for ever to get up to speed...tryed to put it in sport to see if it would fix it...it snaped back to economy....i parked the car...started it back up and the light was off...nowmy tranny m ount is broken and i'm getting it fixed...is it possible some wire came lose? if not what is it
Jan 5, 2008 at 2:40 PM
  • 31,937 POSTS
Hi there,
Automatic transmissions are extremely complex item, the light may well have set a fixed fault code in the ECU. Have that checked, as for the reason for your transmission error, this type of issue would be best discussed with your dealer, i have not experienced this problem in your type of car before, but your dealer may well have a past history and should be able to advise you on what needs to be done, but the very first thing is to have any transmission codes read, as this will be the first place to find any indication of a problem.
Mark (mhpautos)
Jan 5, 2008 at 7:03 PM
GISLOC
  • 34 POSTS
Wellthe light went off when i parked the car and turned it back on...so can they still read a code in it
Jan 6, 2008 at 4:56 AM
  • 31,937 POSTS
Hi there,
Yes, if there has been a fault code set, it will stay there until it is deleted, you can also have fault codes set without the light being activated.
Mark (mhpautos)
Jan 6, 2008 at 8:13 AM
