Left Lic plate light went off, bulb was burned, replaced with OEM eq...no light on left.. RT side Ok, tested with voltmeter no volts..console says"check license plate light"..today when head lights are in auto mode and DRL rear tail lights do not come on, when the headlight switch is turned to full on..the rear lights come on.
No fault messages other that "check license plate light"
Aug 19, 2009 at 3:50 AM
