1994 BMW 530i cost and is it worth it?
1994 BMW 530I
155,000 MILES • 6 CYL • 2WD • MANUAL
BEEMER GIRL 1
my 94 530i BMW needs $ 1300 in work right now: water pump And new fan clutch as well as some new belts, My mech also says there are indications that I might have a leaky headgasket (exhaust fumes in the engine?)Aside from current work that needs to be done the car runs great and handles beautifully. I also just replace the fuel pump this summer.
What is the average cost of replace head gaskets on this car and is it worth putting the money in. It had a new engine put in a 70,000 miles and currently has 155,000 miles
Aug 28, 2009 at 3:33 PM
DOCHAGERTY
  • 9,606 POSTS
BMW had to warranty many of the early M-60 motors due to cylinder erosion, if yours was one of these motors, it might just need a new valley pan, intake manifold reseal, maybe valve cover gaskets. The 3.0 liter V-8 is a good motor and head gasket failure is unlikely unless there was some trauma such as an over-heated engine or missed oil changes. As to your question: to remove and replace both cylinder head gaskets is 152 flat rate units which is equal to 19 hours.
Aug 28, 2009 at 3:50 PM
