ignition key stuck does not turn
BMW 528
ISRAEL LOEZA
I HAVE A 1998 528I BMW, V-6, WITH 103,000 MILES. GOT HOME, PUT CAR IN PARKING AND TURN KEY TO THE OFF POSITION. CAR STILL RUNNING. I DISCONNECT THE BATTERY AND REMOVED THE GAS PUMP FUSE. CAR STOP RUNNING, BUT THE IGNITION IS STUCK, KEY DOES NOT TURN AND THE CAR IS IN ON POSITION. WHAT IS WRONG WITH THE IGNITION SWITCH?
May 19, 2007 at 3:20 PM
DOCHAGERTY
  • CERTIFIED EXPERT
  • 9,603 POSTS
the entire tumbler assembly will require replacement
Jul 22, 2007 at 4:36 AM
