2000 BMW 528
CJENKINS
  • 2000 BMW 528
  • 6 CYL
  • 177,000 MILES
My cruise control isn't working. After replacing the right rear ABS sensor, still have the problem. BMW shop tell me the ABS module, $700, needs replacing. Anything I can try except that?
Tuesday, February 24th, 2009 AT 8:38 PM
2CARPRO JACK
  • 11,533 POSTS
I have forwarded your link to our resident BMW expert. He should be with you shortly
Thanks for using 2CarPros. Com
Wednesday, February 25th, 2009 AT 7:44 AM
DOCHAGERTY
  • 9,601 POSTS
The unit is called a repair kit and what they are telling you is most likely correct. The problem often manifests itself in a fault for wheel speed sensors and that is an indicator of a faulty DSC control module. $700 is what the unit costs, it also needs to be coded to the car.
Wednesday, February 25th, 2009 AT 8:41 AM
