1998 BMW 528 overheating
MARVS36
  • 1998 BMW 528
  • 6 CYL
  • 135,750 MILES
My car started overheating, I took it to my local shop, where they replaced the raditor, water pump, thermostate and housing, all hoses. I picked it up this morning and now it is overheating again.
What could be the problem and how hard would it be to fix?
Tuesday, May 19th, 2009 AT 3:09 PM
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following:, Pressure test the Rad. Cap, Clogged radiator, air lock in the cooling system, Fan clutch, Radiator electrical fan, collaspe hoses, water pump.
Tuesday, May 19th, 2009 AT 4:51 PM
