1988 BMW 528 Battery going dead while dfriving
1988 BMW 528
12,000 MILES • 6 CYL • 2WD • AUTOMATIC
DJALBERTDESIGN
I now own a second hand 1988 BMW 528e. The car is in great condition and i love it except that it doesn't run for long.
When I drive the car runs without issues until the speedometer starts to go crazy as well as a few other gages. Within minutes of that happening the cart stalls and cannot be started without a jump start or charging the battery. Allowing the car to idle or to drive with everything off allows the battery to recharge.
I have not been able to isolate where the drain is.
Can you provide me any guideance on where BMW's may have had a shorting problem, or any information on what you think the issue is.
I have checked for current draw at the fuse box in the engine compartment and cannot find a circuit that is draining while the car is off.
The issue must be a high drain to make the battery go dead whilr the charging system id running. I have a new battery and alternator and still the same problem.
Thanks for any help you can provide.
Dave Jalbert
401 615 3353
Oct 22, 2008 at 8:27 AM
MASTERTECHTIM
  • 4,750 POSTS
im assuming the problem is the charging system. possible defective? recheck connections. the gauges are going crazy from the alternator not charging.
Oct 22, 2008 at 10:26 AM
DOCHAGERTY
  • 9,606 POSTS
It is possibly the brush pack and not the alternator. The part # is 12-31-1-726-022. This part can be installed without removing the alternator.
Oct 22, 2008 at 11:38 AM
DJALBERTDESIGN
I have already replaced the alternator and battery. its possible the new alternator is defective as well.
What is a brush pack?
any other ideas?
Thanks
Dave
Oct 26, 2008 at 3:41 AM
DOCHAGERTY
  • 9,606 POSTS
It is possible the new alternator is bad. Take it to the seller and get it checked
Oct 26, 2008 at 8:18 AM
DJALBERTDESIGN
I will do that. I did the battery voltage test yesturday and the voltage was not steady at 13+ volts, it just kept dropping with time
Oct 27, 2008 at 12:50 AM
DOCHAGERTY
  • 9,606 POSTS
You may also have a parasitic draw that is killing the battery.
Nov 6, 2008 at 2:44 AM
DJALBERTDESIGN
It turned out to be the new alternator was bad. it has been replaced and the problem seams to be gone.
Thanks for your help
Dave
Nov 6, 2008 at 2:55 AM
