1991 BMW 525 Gearbox
1991 BMW 525
88,000 MILES • 4 CYL • 2WD • AUTOMATIC
WINEPROVIDER
i think I`m low on automatic gearbox oil and wondered if someone could tell me how to check the level and where the fill pipe maybe.
A picture would be invaluable.
In anticipation,
Wineprovider
May 2, 2008 at 5:01 AM
DOCHAGERTY
  • 9,606 POSTS
The General Motors built transmission in your BMW has a fill plug on the right side of the main body of the transmission, it is towards the rear and has an 8mm Allen head screw. Check with the engine running and with the fluid temp between 30 and 50 degrees Celsius. Use DEXRON III automatic transmission fluid to bring it back up to normal and find out where it is leaking from and repair it.
May 2, 2008 at 6:59 AM
WINEPROVIDER
Thank you so much allthough I`m not sure if it`s a general motors gearbox.
Its a 1991 model and I think it may be German build.
How do you fill it?
Thanks again,
wineprovider
May 2, 2008 at 7:24 AM
DOCHAGERTY
  • 9,606 POSTS
Fill it through the level plug. It can be pumped in. If it is a 1991 model BMW, then it most likely is a French built General Motors transmission. Please repost with the Vehicle Identification Number.
May 2, 2008 at 10:21 AM
