2004 BMW 330 Sunroof
60,000 MILES • 6 CYL • 2WD • MANUAL
MJ_GARAVI
The roof inner sliding cover is out of place, and does not allow the roof to close. It looks like that the inner sliding cover has broken clips. How do I access, or replace the roof.
Thanks,
MJ
Aug 25, 2010 at 2:50 PM
DOCHAGERTY
  • 9,606 POSTS
The sunroof lid is removed first, then the lid comes out and the repair kit is installed. Push the shade back, put the `roof in the parked position and remove the six Torx screws (three per side) and take up the `roof. Then pull he shade forward and remove the Torx screws on the drivers side glides and take out the shade. If damaged, replace. Install in reverse order. The sunroof lid needs to be a bit higher in the front than in the back or it might be a tad noisy from the wind, dont ask me how I know that!
Aug 25, 2010 at 4:29 PM
