2003 BMW 330 Alternator Replacement
MACL68
Electrical problem
2003 BMW 330 Automatic
2003 BMW 330xi - What steps are required to replace the alternator? Specifically if the idler pulley needs to be removed how is it done?
Apr 4, 2009 at 10:46 AM
DOCHAGERTY
  • 9,606 POSTS
The deflection and tensioner pulleys both have dust caps that are easily popped off to expose the bolt head for the alternator mounting. The tensioner is slackened in a similar fashion, remove the cap and turn the Torx bolt to slack the tensioner and remove the belt.
Apr 5, 2009 at 2:43 PM
