There is also a grinding noise that can come from the same area which I understand may be a bearing needing lubrication. But that is an occasional sound. The air noise is there all the time and varies in intensity as you turn the wheel. It is most noticeable when stopped and you turn the wheel to the right.
RS
SPONSORED LINKS
Monday, May 17th, 2010 AT 12:51 PM
